UFH Thermostats
13 Jan 2016
Can someone please recommend some digital UFH thermostats that can be operated from smart phone (preferably z-wave compatible).
So far the most cost effective system I've found are the Heatmiser Neostats, but they have their own hub.
Any other suggestions? Can be hardwired.
I will be very interested to see if you get any replies to this question.
Going through the same process at the moment and the options seem pretty limited!
I'm reall surprised how little knowledge UFH suppliers have about stats!
We've had 5 quotes and they've ALL quoted including the Heatmiser Neo stats. When I've asked for otherness options they said I would have to purchase my own...
We've already got CCTV on a seperate app so really don't want UFH on yet another app to z-wave!
Nest are too expensive imo.
Heat it are coming in around £99 per stay which is twice the price of the Neos.
I'm looking into Honeywell & z-wave thermostats at the moment but theyre all in dollars and not as much choice in the UK.
Can any plumbers recommend any other thermostat systems that incan check work with z/wave??
Are you looking for individual components or a pre-built system? If you want components to build your own system then Vesternet is the place to go. If you want a pre-built system then Genius Home uses Z-Wave and is about to be upgraded to Z-Wave Plus
I've checked vesternet, the most stylish stats they sell are heat it but they're £99 each. How much are the genius home stats?
Usually in this world some of the best things are the most expensive!
So why not tell us your budget for a stat?
No really, come on I could do with a laugh! You want a smart stat that is WiFi enabled, ITTT enabled, Z wave software and all for less than what?
Here's an idea, get youself a Rasberry Pi and build and design your own. With parts, programming, software, tools to buils it should be cheap enough. Oh wait......
Jon
Jon
You sound a really nice bloke.
I've come to this forum for advice not rude comments.
Like I already said above, heat it are £99 each which is twice the costs of Neo. That gives an indication of my budget.
To the others, thanks for your comments. Heatmiser Neo seems to have everything we are looking for except unable to connnect to a z-wave/zigbee hub. That's the only downside.
I'm not tight by the way. But we need a thermostat for EVERY room as it's underfloor heating zones that we are trying to control.
There's 10 zones in total so you can see why I haven't considered Nest & Genius
