ufh
17 Feb 2008
Berkshire
if i wanted just my kitchen with ufh, could i install the john guest kit just off the flow and return with no zone valves?
We don't know how big the kitchen is, or what the insulation values are.
Why don't you just buy the JG kit for a room of your size, fit it properly and get a decent job done?
If you bodge it it will bite you.
well kitchen is 4m x 5m, newley built so good insulation. I,m just a little lost on the wiring and zone switches and whether to run a new flow from boiler etc. Know anyone that could install it?
You cannot run UFH straight from your flow and returns, the water needs to be blended to reduce the temperature, UFH runs at a maximum of 50 deg C, unless of course you are running your boiler at a maximum of 50 deg C
I thought it had its own blender thermostat?
It does.
http://www.speedfit.co.uk/catalogues/JG_UFHRoompack.pdf
Look on page 5 of the pdf. The two options for installation are shown.
One layout takes care of the UFH delay and the other one with the zone valve fitted allows independant operation.
Its best to fit the zone valve as you can get backflows through some makes of TMV and fitting a non return valve on the JG system looks difficult.
The zone valve is also there to switch in the boiler when needed through the end switch as explained in the link.
