Unable to connect tv to soundbar via HDMI ARC
28 Mar 2011
Conwy
Evening all.
I've just bought a Sharp HT-SB140 soundbar to connect to my JVC LT-43C790(B) TV. My previous soundbar was connected to the TV via the headphone socket, but a fault developed which caused the TV to turn off and reset, hence buying the new soundbar. I'm pretty sure that the soundbar was the issue because when it was disconnected from the TV the problem didn't reoccur.
The issue I have now is that despite connecting an HDMI cable from the soundbar to the HDMI-2 ARC socket on the TV, nowt is happening. I've followed the instructions in the TV manual for connecting via HMDI ARC, scrolling through the on screen TV menu via Home/ Settings/ System/More/Speaker/ Amplifier option on the TV menu in order to activate the soundbar. Trouble is, I get as far as More, but there doesn't appear to be a Speaker/ Amplifier option beyond that. Is there another way to make this happen?
You haven't pressed the mute button on the remote by any chance?
Nothing as simple as that, no.
But I've sorted it: by changing the "sound output" source to HDMI/ARC in the sound settings. As far as I can tell, nowhere in the TV instruction manual does it tell you to do that when connecting a soundbar to HDMI/ ARC.
That would have been my next suggestion. :rolleyes:
