I'm looking at installing the poly pipe overlay system in my 1994 property when i knock a couple of rooms together.
The boiler is a brand new ideal system boiler on an s plan with a non vented tank.
My understanding is that the there will be a new 2 port valve and thermostat to run the boiler on the ufh circuit when required.
The blender valve on the manifold will get the V hot water from the boiler and mix it with the cooler water from the loop return to the preset temp for the loop flow.
Now when the loop is up to temp, the blender stops adding hot water, but the blender pump carries on circulating the water through the ufh.
But the boiler is still turned on, but not circulating the water anywhere as the other 2 span valves are shut.
Can the blender valve not turn the boiler off????
Will it not build up pressure and go wrong??
