"under-performing" toilet
18 Jan 2008
I need help with an "under-performing" toilet. The flushing action has become very weak. The lever needs to be pumped to release enough flow to adequately flush the toilet.
I checked the basin, the water is at the required level but when I flush, water is released into the basin and the flush only lasts 2 seconds.
I looked at a few links on the internet about clearing holes under the rim but i cant seem to locate these in order to clean?
Its not great telling guests to double flush when finished, it brings a bad reaction from guests lol.
Any ideas.
Also, there’s a hissing sound coming from the pump/basin when i continually flush.
Cheers
You could get lucky and have a Turbo Dudley 88 syphon or similar where you can change the diaphragm without having to remove the whole syphon.
Is your toilet close coupled or does it have a flush pipe ?
sounds like a new syphon to me - easy enough for a diyer to fit if its a low level cistern (has a flush pipe leading into the back of the pan) - if its a close coupled one (where the cistern sits onto of the pan) then get a plumber in - can be a tricky job :confused:
