Under units lighting
30 Jul 2005
Essex
Will this work?
New under cabinet lights. Cable from lights into double switch. One for overhead lights (working ok) and the other switch for new with cable chased out into ceiling void.
If I connect this new cable into a junction box on lighting ring will this work? I have two cables running into kitchen ceiling rose, will iether one be of use to feed the JB? If not what do I need to do to get it working?
lighting is not run in a ring, its radial, and i would be inclined to take a cable from the rose, not a jb.
have a look in fro refernce to see how it is connected
Thanks for the reply breezer.
I have the new cable down to the ceiling rose and have connected the live to live and nuetral to neutral. However when I flick the switch (iether the one intended for the ceiling lights or the new under cabinet lights ) the ceiling lights come on in both cases but no under cabinet lights.
Obviously something is amiss but what?
Any help please.
Regards.
Unfortunately I keep getting a short circuit on the new lights.
The ceiling lights are working ok but when I switch the under unit lights on, it trips out. As far as I can see the connections all seem ok.
What could it be?
Thanks for your advice.
Disconnect the cables that are shorting the circuit and connect them up correctly or find the damaged cable.
You either have a short to earth, a short to neutral or damaged cables
If the connections are ok then it must be a damaged cable
DIYKIWI said:
What could it be?
see above
No problem :D
as i said see for refernce, if they do not work, that means you have not followed the instructions correctly.
damaged cable is possible, but unlikely
I take it all back, I've now realised that Part P is a good thing :shock:
It sounds like you have wired the switch so it is connecting LIVE to NEUTRAL when you switch it on... hence the tripping.
The wiring of a ceiling rose is an elegant and simple piece of design. What I would suggest you do is take the cover off a rose that you know is wired correctly, and just try to figure out what all the cables do. Spend maybe 10 minutes with a mains-tester screwdriver (boy am I going to get told off!), and see what wires make it glow when you switch on and when you switch off. It's an easy task, and once you realise what everythnig does, you will go "Ohhhh!!! So THAT'S how it works!".
Then, and only then, when you understand how to wire a ceiling rose, can you figure out how to wire in your undercabinet lights.
Personally, I would say that a junction box is the better way to wire in such lights, as a ceiling rose really isn't practical.
Here is a hint: you will be using all four terminals in a four terminal junction box.
