We've recently installed a Worcester Greenstar 30kw combi c/w RF digi-stat and plug in timer. We now want to install underfloor heating to the kitchen which is 20m2 , is it possible to leave the existing central heating circuit controlled by the existing stat and timer but install a pumpset and blend valve to UFC circuit and install zone valves to rad circuit and the underfloor heating circuit and wire the zone valves and pump to a central wiring centre incorporating a separate programmer /room stat that operates the UFC? or will the two programmer/ timers operate against each other in some way? Appreciate if someone could offer advice on this matter.
kind regards
kind regards
