Underfloor heating system
28 Mar 2011
Suffolk
Im trying to find a system where i heat an underfloor heating system and hot water cylinder from a gas fired boiler whilst leaving the boiler stat at 45-50 degrees for underfloor heating to eliminate blending valves. Does anybody know of a system that incorporates a divertor valve to heat the UFH to 50 degrees and cylinder to 70??
THis is very common in Germany so have a look at the German makers (in no particullar order) Buderus, Strebel, Viessmann. (I think the Dutch ATAG also has this option) ;)
thanks, do you think a high end boiler £1000+....will be much more cost effective than the blending valves??
