It seems strange to me that a room containing a bath or shower is a special location, but outside is not.
And does underfloor heating in a bathroom fall under part p, I guess it does even though it is under the floor.
What is the best way of going about installing underfloor heating yourself, bearing in mind it will be tiled over once the 2nd set of measurements are done and pass within the allowed limits?
Is it possible to install and wire it up your self and then provide all the readings to an electrician (Insulation Resistance and Normal Resistance measurements) who would check it and then sign it off OR would this be the typical case where an electrician would not deal with someone else's work.
If not what should one do and how much should one pay for an electrician.
