Hi, I was planning to lay 12mm ply over old boards and then an insulation layer (prior to underfloor heat element) and then a latex screed before tiling.
My question is mainly what to use for insulation, but I am wondering if my plans are overkill. Just a small/med size bathroom.
Anyone know if the cement tile backer boards (6mm) are decent for insulation? If not, what is thin but good to insulate (don't want floor level rising too much)? I presume you screw the cement tile backer down too? I do like the idea of screed to level the floor nicely and quite like the idea of it protecting the heat elements while tiling but maybe I should just put the heat elements on the ply and screed over the ply?
Sorry if this sounds a bit confusing but I feel a bit confused as to whats best!
Edit: The likes of this sounds fine for some thin insulation but I don't think it's something to be tiling/screeding over hence my question re tile backer board.
https://victoriaplum.com/product/wa...VTLHtCh2nWwpEEAYYASABEgIye_D_BwE&gclsrc=aw.ds
