@MeldrewsMate is correct, a heat pump can raise or lower the temperature by 40°C as we see with a domestic freezer, but we want DHW at +65°C to protect from legionnaires so it is pushing them to the limit in the winter. But you have not talked about heating domestic hot water, and you don't want the floor to exceed 30°C or one would have a problem walking on it with bare feet.
And yes if a doctor has seen a some one and decided they need weighting or an injection then they can pass the work on to people trained to a lesser extent, and in the same way engineers will assess what work can be passed to tradesmen or mates.
But when I went to my mothers house, which had the whole system renewed, and a combi boiler installed, by a so called specialist firm, it was to put it mildly a mess, in the main lack of commissioning, but when I came to try and improve the system it was not as easy as I thought, I tried wall thermostats, and programmable TRV heads all improved it but still not good enough, the cure was adding a TRV head to hall radiator where the wall thermostat was, which was against every recommendation I had read, they all said do not fit a TRV in same room as wall thermostat, but in mothers house it worked.
In my trade/profession I have walked into a situation and like Miss Marple who done it, I realise I have seen some thing similar in the past and can dispense with a load of calculations and simple inspect and test on completion, very few times do I need to sit down with the slide rule and work it all out. But some I realise it is going to be on the edge, so it is a case of working it out first, and deciding if it will work.
Some tradesmen are very good, others are to be frank are little better than a mate. The we do it this way, why? because we have always done it this way. So with an extractor fan 85 m³/h in a bathroom the heating must replace that heat, it does not take that much to realise a 300 watt electric UFH is not going to replace the heat being blown outside, without the extractor it may have a chance, or with a heat recovery unit, or if it was getting replacement air from some room already hot, but from the cool hall no chance, and to be frank had it been more than 300 watt would have been no better as floor about as warm as one would want it to walk on.
The 30°C limit means UFH takes a long time to get rooms warm, in the main today we look at less than an hour to warm a room, so in the main looking at a hybrid system to get fast warm up. Of course some premises care homes for example are never allowed to cool, and having no radiators for wheel chairs to hit or people to lean on is an advantage. But in my house I want it cool at night.
