We're in the throws of building works which consist knocking through two rooms of the exisiting house and adding an extension to form a 60m2 open-plan area. We'll have bi-fold doors along the face of the extension plus other windows and intend to fit engineered wood flooring. We are considering UFH (water) to heat the entire space. At the moment we're working with our builder and his plumber to assess the best system but I'd like to gather independent views based on experience. Also, we've had a few comments from friends who've chucked their sixpence worth regards UFH as a sole source of heating...I'd appreciate views on:
1. Friends (with UFH) reckon heating a room of this size with just UFH won't give a truly warm environment in the winter, we'd be as well to add a few rads as 'back up'.
2. Warm up time is long (I thought UFH is always left on?)
3. It's expensive to run
4. Thickness of the flooring is important and should be no more than 15mm engineered (oak)
5. New extension is a screed floor, existing house is a suspended floor - different style of pipe work will causes issues? (Two zones, two thermostats I guess)
6. For the instalation, should we be looking for a specialist plumber/fitter and is it normal to expect a warranty of some kind? Our builder's plumber has fitted before but isn't a specialist as such.
Personally, with proper calcs done for the system required plus a competent plumber, I can't see why UFH can't do a job on it's own but, there again, I've no experience in this. Any views/advice welcome.
