Hello,
We have recently purchased a new house in Amsterdam - on a man-made island called Ijburg. It's unique and modern in a lot of ways, and one such way is the absence of gas to any properties - everything is done through "stads verwarming" - or city heating.
This basically means the power station (also on the island) pumps hot water to the property. This is then used for your hot water supply AND to heat the underfloor heating, which is installed in each home.
It is a closed circuit system, with water as the "fuel"
Now, the problem we have is that we put carpets and underlay upstairs and laminate downstairs - we followed all guidelines re: carpet etc... but, with only 1 thermo stat, it is causing a large temp difference. approx. 2.5 during day and 5 degs by the time morning comes around again. We are cold at night
The system has 2 manifolds - which appear identical.
On each manifold (after consulting with the company that installed the systems) - there are 2 thermostatic valves.... one controls the supply and one controls the return (water back out the property to the power station).
Also on each manifold is a small box which has an electrical supply and is attached to the pump on each manifold - according to the company that installed it, this is a device that cuts of electricity to the pump if the temp. gets above 60degs C - to protect the system / floor from over heating.
The problem I have, is that apparently the power company that controls the water to the properties, has regulations that do not permit the supply valve to go as high as 5 (it has dial 1-5) - I believe it is only 1-4 that is permitted. In our case, each valve is locked and will not allow us to get above 3.
My thinking was, I could turn the supply valve downstairs to 2, and upstairs to 4 - and then trial and error to get a balance.
With the mis-match in temperatures, there is what feels like a constant draft. But, It is looking likely, that with the carpet floor coverings, no matter how long the heating is on, I can not get above 20.5 degs upstairs - so I really need to try and get the supply turned up to 4 (but as I stated, this is locked) in the hope this can raise the temps. According to installation company, 1-5 represents the following:
1 23° C 2 34° C 3 45° C 4 56° C 5 67° C
The other option is to have a second thermostat fitted (there is, in effect 2 heating systems in the house) - but, the company wants EUR 1500 to make this a 2-thermostat (wireless) system - which is just waaaay to high.
I considered installing a google Nest - but installation company says this is not possible as it is a high voltage system - although, I'm not so sure it is.
I took the thermostat off the wall (as it detaches, in order to change batteries - you can see pic) and took upstairs with me, and it monitors the upstairs temperature as expected - as the sensor is on this unit - and, it appears to control the heating as it does when downstairs....
So, my questions(s) are:
1. Can anyone see from the pictures how the actual communication between the thermostat and heating system is taking place?
2. Do you think I can install a 2nd thermostat for less than their really high quoted price?
3. Does anyone know anything about this temp limiting device? There seems to be a small selector on each unit, with options 1,2,3 - downstairs is at 1, upstairs is at 2.
4. Any other suggestions? - we are very cold... and I'm not a heating let alone an underfloor heating expert
5. Temperatures in different rooms are almost a degree different - any idea's why? (all the flow vales are fully open) We placed thermometer in our sons room (which has 2 windows) and it was 1 degree colder than our own room..... the windows do not appear very draughty
I feel the company may be exploiting us a little bit, in the hope they get more money - the property is less than 6 years old.
thank you for any help....
Neil
Neil
