underfloor heating
29 Jun 2006
Lancashire
i have had underfloor heating and also a Spa bath fitted today. The guy has wired both new appliances in the small room next to the bath room and put 1 fused switch.
Is this ok ? there is also a thermostat next to the fused switch. Should the appliances have seperate fused switches ?
Thanks.
thermostat element is embedded in the floor with the underfloor heating so thats ok, does that one spur switch off both? usually one each. did you get a cert or receipt for work?
I have to agree. No matter what the installation, there has to be a good reason to break the every appliance needs its own switch rule.
Yes the one switch will turn off the bubbles in the bath and also the floor heating.
Did get a receipt and also a certificate thing with lots of equasions and values on it.
