I'm in the middle of laying some 110mm pvc pipe from a new downpipe to an existing soakaway.
I've had to fit 2 x 30 & 1 x 45 degree bend to the pipe work in various stages, I've cut the pipe square and pushed it into the joints.
Does it matter if they don't fit bang on square in the joint e.g I've used a 30 degree joint and the angle of the 2 pipes may be 32-33 degrees?
Thanks.
Thanks.
