Undermount sink cradle reccomendations (or comments)
16 Jan 2012
Uk
I have a composite undermount sink to fit. Due to space constaraints, it is going into a 600mm unit, with granite work surface. The fixing instructions for the sink suggest a method, but it appears impossible to remove the sink, if ever neccessary, without removing the work surface, so am not going down that (though cheaper) route.
I have found many cradles, but few that will fit a 600 mm unit. Ideally, it will have adjustments height wise after the bars are installed.
Has anyone got any recoomendations, please?
I used vertical brackets fitted at an angle to support the underside of the basin because I didn’t trust just using the clips supplied plus sealant. But in hindsight the clips plus a OB1 type sealant would have probably been fine. I used a normal sealant not a hybrid polymer as I wanted to be able to remove the basin if needed.
