I'm about to lay DPM, 100mm insulation and 55mm of liquid screed, on top of my beam and block floor.
In some places, the beams are slightly taller than the blocks, by maybe up to 10mm. Note sure if the blocks were a bit under size, or the beams over size.
My concern, is that the insulation wont be fully supported and that the screed may later crack because the insulation can deform slightly between the beams where its supported.
Is this a common thing? Do I need to put down some sand or very weak screed to get an even amount of support everywhere under the DPM?
