I am undergoing a total renovation of my house and have laid an 18mm solid oak floor in the hall way. The subfloor has recently been concreted and I wrongly assumed it would level and laid the floor on 5mm thick fibre board. The floor looks pretty good but there is definite high and low points under the floor and its bouncing in areas and lifting in others. I am simply not happy with the job I have done but it is glued so not sure if anyone can tell me if there is a way to pull it up and relay without too much damage or is it staying in situ until I can afford to replace properly?
thanks from a numpty novice floor fitter
