Unsatisfactory main house water pressure
As a late arrival to this thread a question - have you tried taking the water softener out of the circuit? Does that make a difference?
I spent a bit of time at the neighbours yesterday in order to understand the state of their system and I was surprised to find that they do have some of the conditions that we have:
- Tap pressure appears similar and has some of the same surprising characteristics such as the downstairs toilet being weaker than the utility tap
The basins in the downstairs toilets may be intentionally fitted with restricted-flow "water-saving" taps.
That’s an interesting point that could explain it. We noted also that the taps appear to have puny piping - 10mm or even less
Additionally we measured the pressure from the garden tap and got 1.6bar
I’m now inclined to think we may just need to fit a booster pump in the airing cupboard to serve the bathrooms
Nope, not as simple as that unfortunately. You could use the small in line booster pumps I guess but that's just getting reeeeeally complicated with multiple points of failure. That and if it draws more than can be made up by the mains then system could get into all sorts of bother.
If the property had an unvented cylinder installed from new then I'd find it hard to accept that the mains wasn't able supply both the cylinder and the cold throughout the house from the get go, it wouldn't have passed muster if it didn't. If it can't cope without being pumped then it's going to struggle no matter what. Anything that is mains fed, undoubtedly the whole house cold and hot by the sounds of it, would have to be supplemented by a mains pump. They only deliver 12L/Min at around 1.2 bar, if you mains can already supply that level, then the mains pump will never be utilised.
Even if the other outlets are fed by 10mm pipe, there should still be enough mains pressure to supply everything. Has your neighbour been in since the house was new and have they always seen issues? Does the pressure at the outside tap stay around 1.6bar when say 2 or three outlets are open at the same time or does it drop off markedly?
Hmmm interesting....
Regarding the state of play when the house was new in 2014, it doesn't seem impossible that, since the supply would have been serving fewer houses back then, that it did have better pressure. We do, for example, have the problem that we couldn't get fibre internet to the house due to lack of capacity. ie. they installed the service but then the number of houses expanded beyond the capacity.
They haven't been in the house since new. As I say, the taps seemed somewhat similar to here (and they also have the fundamental prob of not being able to run multiple taps at once) although the shower seemed somewhat more powerful, or at least they don't have the wildly inconsistent pressure that we get:
- Reasonable power for the first ~20 seconds
- Drops right down to something like a dribble for a couple of minutes
- Can return to moderately acceptable pressure
The previous owner here bought in 2014, but she simply said "never had any problems with water pressure", which it's really a very powerful (or detailed) testimony.
At least if the supply pressure was consistent, we'd be able to live better with it
That's one to check when I have a moment
When you had the incoming mains tested, the supplier should have given you written findings with time of day, flow rate and pressure.
Did they issue you with this?
Also, not uncommon for developers to allow dirt to get into 1st fix pipework during construction and then not flush carcass out before installing end fittings.
If the incoming main is proved good (12lpm ain't great tbh) then likely you have something in the pipework that is getting moved backward and forwards during use and no way for it to escape.
First thing I'd try is to remove shower valves and flush out the pipework.
They actually did not. We measured it manually with a tester device like this https://www.screwfix.com/p/monument-tools-mains-water-pressure-test-gauge-11bar/82412
Yes this has been suggested. Is this a costly job? Seems that with the right equipment it wouldn't be so?
Not if you can pinpoint where it is. Systematically start at the incoming valve and test at various points from there until, hopefully, you see a marked drop in pressure/flow
You need them to measure it at their meter/stopcock, not yours.
Right... I think he went out and took a look, but he didn't report back any numbers other than it must've been > 0.7 bar or whatever...
Every time I've asked a customer to do this, with a view to installing an unvented cylinder, the water carrier have attended and left a documented report.
They can be a bit funny about it so I always advise customers to say it's because they think there might be an issue with the supply from meter to internal stopcock.
Flow rate is more important than pressure
You want around 20Lpm and 1.5-2.5bar in a perfect world.
- Water pressure is unsatisfactory and inconsistent mostly throughout the house, but with the exception of the utility room
Is the photo in the opening post the utility room?
If the utility room (and garden tap by the sounds of the photo labelling) flow is fine and everywhere else isn't then I'd be starting my search for the cause based on that fact. Specifically, what makes those two locations different to all the others? If the utility room and garden tap are fed from the mains *before* it disappears off upto your airing cupboard and everywhere else is served *after* it then it could be down to a (partial) blockage in the pressure reducing valve (which provides a balanced feed for both hot and cold water).
I come across many new builds where supply to the UV is decent bore but then dirtibuted from the cylinder, all over the house in 15mm plastic, feeding basins, toilets and showers with tees everywhere.
It does seem very much like this yes. In other words, that the internal pipework is rather restrictive?
