I've got two bedrooms in an extension where the flooring is really botched and falling to bits. It's a mish-mash of bits of chipboard with various bits chipped and broken, so I want to replace the whole thing properly.
So my first question is, should I replace with subfloor-grade chipboard again? Not sure what's a realistic alternative other than T&G floorboards. Is this actually any better?
Also, what's the best way to insulate under this floor? I've heard from some sources (can't remember where, somewhere online) that you shouldn't really insulate upper floors, only the ground floor. If I do insulate, what should I use - just loft insulation? If so, how do I suspend it beneath the flooring to keep a void for air flow and electrical / heating pipes?
Thanks...
Thanks...
