untreated or pressure treated wood in loft space?
6 Oct 2004
Sorry if this is a stupid question, but I can't find the answer anywhere.
Obviously you have to use pressure-treated wood under the ground floor, as its old and damp. How about in a cold ventilated loft? I always thought that as you get a lot of airflow, which would remove damp air, regular untreated wood shoul be suitable for use in the loft. But would it be better to use pressure-treated wood in the loft?
Cheers
gtgt
In theory the roof should be well ventilated however there is always the possibility of vents etc being blocked up or removed by naive owners/builders and leaks can occur also leading to wood getting saturated for long periods of time before discovery. If its a new roof then it has a fair chance of getting wet during construction too.
