Unused water tanks?
29 Jul 2008
London
I moved into a property where the boiler and hot tank where replaced about 5 years ago (it is now a potterton and a ozo hotwater unvented water tank). I found 3 water tanks in the attic which seem to be unused.
I need to make sure they are unused as I want to get rid of them. I went up there and ran the cold + hot taps and the level of the water did not change, which would suggest that they are not used. However when I went up there the tanks were both still full of water. I would assume that evaporation would have made them empty by now (one was uncovered).
So is there a way to definitively check that the water tanks are not being used?
check any pipework off them is capped off. check all the outlets.
is their still a ballvalve connected to the mains ?
if you dont own the whole building they may belong to other flats !!!!
If they are not being used then at least drain them as the water may have been there years! :wink:
I will check if the pipes were capped off, but could it be that it was capped off not on the water tank side but somewhere else?
I don't know about the ballvalve. I suspect it might still be connected to the mains for filling up, that would explain why there is still water in the tank after all this time.
Another point is that neither water was hot. I would assume that the tank covered in insulation was the hot water tank and it was cold.
The two big tanks had surprisingly clear water, which was a little worrying, the little one was looking pretty lively.
I was a little scared to even look in the covered one. :shock:
it won't be hot it just supplies the hot water cylinder with cold water the water is heated in the cylinder.
