I've started to renovate an old cottage and have started to dry line some of the walls, as there's no insulation - render onto stone, very cold!
Anyway the problem I've got is attaching the corner bead around the opening for the windows as the angle isn't anywhere near 90 degrees, it's more like 45 degrees! This is an old cottage with 600mm thick stone walls, where the window openings 'flare' out from the window frames. Any ideas??
I'm also using jointing compound to hide and feather in the beads prior to sealing. Is this right??
Cheers
Cheers
