    Dismiss Notice
Unvented cylinder install
Discussion in 'Plumbing and Central Heating' started by Hp1, 19 Sep 2021.
  1. Hp1
    Hp1
    12 Dec 2005
    387
    Thanks Received:
    59
    Middlesex
    Country:
    Hi?
    Any registered gas engineers able to install an unvented cylinder/convert gravity system in Camberley, Surrey?
    looking to get the work done ASAP
    Harry
  2. oldbuffer
    oldbuffer
    6 May 2010
    1,438
    Thanks Received:
    535
    London
    Country:
    Its not a gas registered engineer you need, its someone who holds a current G3 certificate. Such a person will be registered with a "competent persons scheme" which may or may not be the scheme run by Gas Safe. Being Gas Safe Registered does not automatically make a person G3 competent.
    • Like Like x 1
  3. Sponsored Links
  4. Hp1
    Hp1
    12 Dec 2005
    387
    Thanks Received:
    59
    Middlesex
    Country:
    Thank you for your reply. Indeed I am looking for someone G3 registered. However, I believe the qualification is most likely to be held by a Person installing boilers/CH systems hence my post requesting a Gas safe registered engineer.
  5. muggles
    muggles
    28 Oct 2005
    13,342
    Thanks Received:
    3,077
    Daventry
    Country:
    You can search the Gas Safe, OFTEC, and APHC websites to find people who are qualified to install unvented cylinders in your postcode area. Mike Walton is close to you and a good installer though http://www.mwtheplumber.co.uk/index.php/products
    • Thanks Thanks x 1
  6. Sponsored Links
Loading...
Share This Page
