Which unvented cylinder is good?
7 Nov 2022
Hi, I am looking to replace the gravity water system with unvented indirect hot water cylinder.
I came across quite a few different brands online and wondering which one is best to install.
I will carry on using the standard 18KW worcester boiler with the new unvented cylinder.
Here is the list,
- https://www.tdlonline.co.uk/Heating...rd-Tempest-Vertical-Unvented-Cylinder-TSMI200
- https://www.tdlonline.co.uk/Heating...ct-Unvented-Cylinder-Stainless-Steel-PLUIN210
- https://www.plumbnation.co.uk/site/...co-210i-indirect-unvented-hot-water-cylinder/
- https://www.plumbnation.co.uk/site/worcester-green-storage-wb-210-litre-unvented-cylinder/
No good plumber will buy a pre plumbed cylinder. This also shouldn't be up to you to specify, the coil size needs to be appropriate aswell as the overall cylinder size. You may well want a heat pump within the lifetime of the cylinder so other coil may be beneficial etc.
