- Joined
- 2 Dec 2015
- Messages
- 1
- Reaction score
- 0
- Country
HELP I've got a unvented water cylinder, when i start to heat the water up it starts to leak water from the pressure relief valve on the multi bloc, if i turn on the hot water tap it stops. the water continue to heat to 60 degree with out it leaking ????
the vessel is new and so is the pressure/temperature relief valve ???
