unvented system inlet pipe
11 Dec 2007
Essex
I have booked to go on unvented training day
but I have been asked to price putting in a unvented tank
the work will not be done till I have done the training but so I can price the job right can any one tell me if the inlet pipe on a 300L mega flow can be in 15 mm I can not seam to find any info on it
my standing press is 4.8 bar
and the flow rate is 14 letters a min
is this ok
only running a bigger pipe from the mains is very very hard and the stop cock is 15 mm
thanks
14 ltrs a min is useless for a megaflow anyway, are you sure you're measuring it right?
sooey....i agree....measure again.
not normal (in leicester anyway) to get such high pressure and low flow)
i used a flow cup that I got of e bay and had no paper work
Where do you take the reading from
I took it that where the water comes out the side that s your flow
HI
15mm for 300l tank no good .minimum 22mm inlet pipe required.common sense.
