Hi guys,
Wondering if anyone might be able to help... I have an unvented system and a leaking hot water tap for the upstairs bath. To sort this I am hoping I can just isolate the hot and cold water to the upstairs (to reach the bath taps I will need to disconnect both pipes) fix the leak and then turn the valves back and let the water flow again. Based on the isolation valves being the red and blue handled points at the top left of the image below (the pipes feed hot and cold water to upstairs), would anyone know if this is OK to do?
There is also a showers balance pipe (see second image) do I need to do anything with that?
Any help greatly appreciated and I can supply more phots/info if needed. If the answer is get a plumber I will do that just if its as easy as turning these valves then I should be able to fix the leak myself.
