I want to provide H&C water to a small sink in a garden toilet. I have identified the Redring MS6 undersink unvented water heater and want to double-check my interpretation of manufacturer's instructions (MI) as to whether an expansion tank and associated fittings is mandated or can be omitted.
The water supply from the main house will enter at one end of the building underground and the first draw off will be a WC cistern. Then there will the be a run of ~2m to a location below a basin where I want to install the heater to feed a mixer tap on the basin. A cold water feed will be needed as well, of course.
According to MI, an expansion tank is required if the pipe from the heater back to the "nearest cold water draw-off" is <1.7m. In the set up described above, the cold supply to the basin mixer tap willl < 0.5m from the heater, so it appears an expansion tank is needed. However, if the cold feed immediately downstream of the WC cistern is split so that the water heater and the cold feed for the basin have separate runs, I can meet the minimum 1.7m stipulation?
Does this idea work?
https://www.redring.co.uk/sites/default/files/assets//MS6 booklet New 2018.pdf
