Hi everyone, I need some help. Put up some lights in the lounge and hall worked fine thought I had followed the old and new. Then I switched on them both at the same time and the hall one goes out (dims with the dimmer) when I switched the lounge one on. Doh!!!
Actually left it for ages as I could cope with it but selling the house now and need to fix it, tried lots of combinations but cant seem to fix it.
Hall
2 cables in, reds together in an isolated block and blacks to each end of the light. Cant see how i could go wrong here unless the reds and blacks are wired wrongly (Note: I tested blacks together in the block and red to each end of the light and this also worked?)
Lounge - Three cables in. Reds together in an isolated block
No red helpful tape on any of the blacks so I have labelled them as none, white and duck(duck tape). My test results are below and hopefully this will show what happens. If I havent mentionned a wire it means it is isolated:-
White(L) and None(N) Hall switch turns both lights on at half strength so I presume duck may be the lounge switch?
Duck(L) and None(N) Neither work
Duck(L) and White(N) Neither work
White(L) and None(L) and duck(N) hall light works from hall switch and lounge does not.
Help please!!!
Hall
Help please!!!
