I'm in the planning stages of my next project which will be a new kitchen.
Part of the plan involves replacing a single (built under) electric oven with a double (built in) oven.
Obviously, this also involves moving where the oven is located.
I've done a bit of research into doing this so now I have what I hope is a short list of questions.
1, The shut off switch.
The current oven has a master switch on the wall which then runs down to a cooker plate type junction box behind the cupboard next to the oven.
The existing single oven is then hard wired to that box.
I've read that your master switch should be no more than 2 metres from the oven itself.
Is that as the crow flies or are we talking about length of cable from the switch (or junction box)?
Basically, my kitchen really isn't that big, so if it's as the crow flies I'm cool, but, if it's cable length I'm probably a bit over.
Ideally I'd like to just leave the switch where it is and run a new length of cable round the back of the cupboards to the new oven.
2, Supply/Rating.
Is there a simple way to check the current rating?
From what I've read I'm 99% certain my new oven will need a 30amp breaker - I'd be surprised if it didn't.
Without sounding stupid - how do I check what breaker is currently in the consumer unit?
Luckily for me, the consumer unit is in the kitchen and is also directly above where the master socket for the current oven is, so I guess if I had to install a new ring (or whatever the correct term is) it wouldn't be the end of the world, but I'd rather not if I don't have to!
(Clearly I won't be doing that myself - but it shouldn't be a biggy for a sparky).
Thanks in advance....
DIYC
2, Supply/Rating.
DIYC
