Upgrading bathroom extractor fan
28 Sep 2007
Berkshire
Hi there,
I have an in-line (I think axial) extractor fan in the bathroom. 100mm diameter located above the ceiling ducted to the external wall about 2-3metres.
The fan is almost useless as the room is always very steamed up after a shower. The fan barely holds a tissue when completely covering the vent!
I want to upgrade but think that it will be very difficult to install through a 100mm hole - not sure if a replacement will fit through?? For this reason, I was thinking of installing a surface mounted fan?
Can you advise please:
1) is it possible to work through a 100mm hole to replace the in line fan and if yes, what would you recommend?
2) What surface mount fan would you recommend and do I need to remove the inline fan ( I guess so!).
All thoughts appreciated!!
BTW...room is c. 12 cubic metres.
Thanks.
Whatever you end up doing you're going to have to access the existing fan i.e. to remove it if fitting a surface mount fan or to replace it. I'd suggest the latter and, given the length of ducting, your only viable option here is a centrifugal fan. An axial fan simply cannot overcome the pressure drop hence it'll just sit there spinning in a stall and having virtually no effect at all.
I can highly recommend the Manrose CDF200T e.g. from TLC or, cheaper but harder to link to(!), part number 18223 from BES. It's cheap (~£35), works extremely well over long duct runs, runs very quietly and has an adjustable run-on timer.
Mathew
