I am currently planning to upgrade the mains circuit in my Victorian house. I currently have an old style (fuse wire) board and it seems that all of the sockets throughout the house are on a single radial circuit.
I am intending to get an electrician in to upgrade my fuse board to a new CU with RCDs, plus running some earthing cable from the bathroom, however I would also like to change the mains radial setup to two (up and downstairs) ring circuits.
Assuming that I get an extra RCD fitted to the CU is there any problem with me simply locating the last of the upstairs sockets and running cable back to the CU on one RCD. Then disconnect the cable between this upstairs socket and the downstairs socket and run another cable from the downstairs socket to a new RCD at the CU. Finally I would then need to locate the last socket on the circuit and run a cable from there back to the second RCD.
Does this make sense to you? Is there anything I am thinking wrong?
