upstairs ceiling cracking - how to reinforce loft joists?
16 May 2010
Gwent
After paying out to have the upstairs ceilings replastered (skim over the horrid artex) we've since discovered that something up there is on the move:
- There's a crack formed in line with one of the joists across the span of the master bedroom.
- Several nail-heads have popped their plaster off, leaving a line of craters.
I think the problem has been compounded by the orientation of the original plasterboard. I was intending to partially board out and use the loft for storage, but this development has kinda thrown things into doubt.
I was told by a QS friend that the roof/ceiling construction is of a suspended type: There's 2 generous beams running parallel to the apex that sit above smaller ceiling joists (probably 3 - 4inch deep) *
I suspect there's no co-incidence to the fact that where this 'problem' joist is, is also where the one of the main beams is jointed - there's an overlap of about 1m between the beam and its successor, but I think the joint between them isn't too rigid.
So, questions:
How can I stop the ceiling moving, and also re-inforce the loft floor to take loft boards carrying boxes of junk?
This needs to be minimal hassle/intrusion into the living space, i.e. not tearing ceilings down. And preferably not vastly expensive using expensive materials or techniques that require a tradesperson.
I was considering (in sequence):
1 strengthen the iffy joint on the main beam, drill & bolt? Glue?
2 installing thicker joists parallel to the existing ones, but how to secure to the beams? place on top, or alongside?
3 board over.
*Can upload photos tomorrow if required..
Failed to get a camera up there, but managed a tape measure:
ceiling joists are 1.5" x 4" deep.
Supporting beams are 2x4"
on average 450mm (18") between joists (this figure varies a bit)
about 2.1m (7ft in old money) between supporting beams
The ceiling line is above the eaves of the house - the ceiling drops by the outside walls of the upstairs rooms. I've no idea if this is relevant.
Another detail is there's some massive C-section steels bolted to the roof trusses, running parallel to the line of the terrace. I believe these were installed shortly after the terrace was built to remedy some subsidance that has obviously happened in the pasts.
Any thoughts anyone?
