Hi, I'd be grateful for some advice on the following,
After removing some an old ceiling in a 1920's house as the floor boards upstairs in the corner seemed to have some give in them I have found the reason why.
The partial beam that should have tied into the corner of a box section frame going round the concrete first floor hearth has split where it was cut for the central heating pipes some years ago.
I'd like to beef up the beam and also removal some of the dead weight from the surrounding area.
There are two rooms with a supporting wall between them, in each upstairs room there is a fire place (towards the centre wall), in the smaller of the two rooms where I want to replace a beam there is a chimney breast which seems to be built partially over the central supporting wall and partial using corbel brickwork. However in front of the fireplace is a bit chunk of hearth set into the floor boards.
Can anyone tell me if it's safe to break this up and removal it without interfering with the chimney breast, upon inspection it would seem so but thought I'd just check. If I can remove this concrete mass then it will allow me to extend the damaged joist across onto the centre wall and make everything a little better.
What's the best way to break this up?
Any comments gratefully received.
