Hi
Im after some help please.
The hot water in my shower started going intermittent hot and cold and did not really get that hot. Its not electric, it runs from the boiler with the hot and cold going into a thermostat that you control. I thought the cartridge in the thermostat had gone so ordered a new one but I still have the same issue. I might be unlucky and the cartridge I ordered may be faulty.
Im trying to work out if its a boiler issue or an issue with the pipes. It looks like the same hot feed pipe from the boiler feeds all the hot taps, both up and down stairs. So far I have done the below tests
1) Ran the hot taps in the kitchen and downstairs sink. They work fine. I watched the boiler as they run and it sits at around 65 degrees and gets hot. The pipe that feeds these from the boiler are hot to touch, so looks like no issues
2) The same pipe feeds the shower from the boiler. This gets luke warm when I run it and does not get as hot as above. However the boiler temp display is higher and goes up and down between 75-85 degrees when I run it.
3)The same pipe from the boiler feeds the bath. when they are turned open more the water does not get piping hot, I have to turn it lower and it gets very not but it has to be on a slower water flow but does stay consistently hot
Has anyone please get any ideas on what the issues could be, is it the boiler or something wrong with the pipes to the taps/shower?
I really appreciate your help
Thanks,
Simon
Thanks,
Simon
