UPVC Door Handle
3 Aug 2011
Flintshire
Hi all,
Hoping for a speedy response if possible...
My front door handle on the outside has stopped working. The inside handle opens the door if you push it down, the outside handle used to also open the door if you pushed it down. However one of my kids slammed the door, now you can only open the door from the outside using the key.
I've taken off the handles to see of the connecting rod between the handles had come out, but couldn't really see anything out of place.
Help! :confused:
Thanks in advance!
Sounds like the "split spindle" has been knocked out of place.
Refit it testing as you put each handle on.
Thanks :D
I wasn't too sure about removing the assembly as I've never done it before and I wasn't sure if I might knock some of the levers out of position and make things worse.
I'm good at fiddly things and generally a good alround DIY'er (Having just build my own extension), so do you think I could strip it down and get it back together ok? Suppose if worst comes to the worst I could alwayd replace the whole locking mechanism.
So split spindle, what am I looking for exactly?
Well its the spindle thru the handles, just dissamble and reassemble.
Just remove the handles, I have come a cross a few times with splindle being too short!
Hi all,
I should point out that the handle on the outside works to lock the door, i.e. when you pull it up to lock the door, it just doesn't work when you push it down.
Am I looking at an internal mechanism / gearbox problem?
