hiya all had a new back door about a year and a half a go, had a few problems with it - i end up with the suppliers/fitters approval putting a new screw in as it was coming away from the frame, and its always been tight when it heats up in the conservatory, these problems aside all been ok
noticed today that the middle hinge has a sight crack on it (its the only hinge that is more at a slight angle as appose to being straight) guessing adjusted by the fitted.
anyway its about a inch crack, could this cause problems, i see that these can be replaced? worth while doing? worth while advising the company that fitted it, or just best to leave it and see if it gets any worse (could it)
thanks in advance
thanks in advance
