UPVC door lock mechanism identity
7 Dec 2018
Hi All,
When you push the handle down on our front door the handle doesn't spring back to the normal position. I don't know if the mechanism can be fixed or needs replacing. It says Wink Haus on the metal strip and 92. Is there any more information I would need to order a new one?
Thanks All
I have just removed the mechanism and on the gearbox it says 35/92 and there is a label with the part number 1032127 RH. I have looked online and can't find this part anywhere, so does anyone know what I can use instead?
Got a picture of it?
Normally Winkhaus are riveted on to the faceplate and unless you want to drill and re rivets, then you will need an entire locking mechanism, gearbox and faceplate
Winkhaus is usually the cobra.
@ronniecabers, not sure that you're aware but whilst the winkhaus gearboxes look riveted on they are in fact replaceable if you punch out the pins, see here
Thanks everyone for your replies, I've ordered the cobra which arrived today, fits but needs a bit of fine tuning.
