UPVC Door locking mechanism issue
3 Aug 2011
Bute
Hi Guys,
Any ideas what would be wrong with the door and what would need checking or replacing.
Once i close the door i pull the handles up and i lock the door with key. Issue is when you force down the door handle real hard it seems to open the door?
Any ideas?
Does it open the door or not?
seems is a bit vague.
Yep as i mentioned when i push it down it seems to open the door when it shouldnt as the door has been locked. I also changed the cylinder but still had the same issue.
Also noticed when the door is open and i lock the door i can press the lock back in by pushing it inside (this is the thing that sticks out on the side when u lock the door)
