uPVC door stuck after hearing something ‘drop’ inside
8 Nov 2020
Hi all, so I have a uPVC back door and last night when I tried pulling the handle up to lock it, I heard something drop inside the door and now the handle just moves up and down freely without engaging anything - so the door is stuck closed
From my research it appears to be related to the gearbox, but to identify the model and what replacement I need, I have to open the door to see what model gearbox it has. But I’ve tried many methods to open the door with no luck - I’ve tried wedging wallpaper scraper in the gaps to try to loosen the latches but I’ve had no luck. I’ve also taken the handles off and used a flat head screwdriver to turn the spindle but again it doesn’t work.
I have noticed that there’s quite a large gap between the door and doorframe at the bottom and middle of the door, but I’m not sure if this is new or not (pics attached)
Any ideas on how I can actually get the door open? Or what the problem could be?
Ok so my first thought was the square drive in the gearbox had disintegrated allowing the handle to just spin but it looks intact, I'm assuming the spindle was using the top square hole, try putting the spindle in the handle and trying the lower hole, see if it'll open
