Hi the espag handle on one of the upvc has become very tight to close.(top opening type) so i changed the
Handle but still the same problem i.e.tight. so i think possibly the dead bolt gear mechanism is faulty.
If so to replace the same will i have to remove all the extensions or is it just to remove two screw which
Is holding the gear mechanism which is marked spectus and straight forward replacement..thanking
In advance for all the help/advise
P.s. if poss advise where i can get replacement spectus part
