UPVC window - fire hinges
31 Jan 2009
Yorkshire
We have a upvc window in the 1st floor bedroom, it is a large opening window with a i think hinges that are fire escape / easy cleaning. The window i think is supposed to open and stay open at 90 degrees on its own. However the window when pushed open just slowly closes. Is this a knackered hinge or do i need to do something with it. The window has never stayed open on its own since we moved in so not something we have done.
Lee
Should the worst happen and a fire occur and you need to escape via your escape window, as long as you can get out through the opening somehow I doubt whether it stays open or not will enter your mind!
Don't worry about it.
Open the window,there should be a plastic bit that slides up and down when you open and close the window, on the plastic part there should be a little screw, just tighten it a little.
