    Dismiss Notice
urgent advice needed
Discussion in 'Plastering and Rendering' started by benwilliamson, 7 Jun 2010.
  1. benwilliamson
    benwilliamson
    23 May 2010
    24
    Thanks Received:
    Lincolnshire
    Country:
    hi took a shower cubical out today in a newish chartdale house 20y old all around the bottom of the tray has been leaking, as normal, all the plaster has become water damaged and behind the plaster is just straw how do i fix this cheaply and quickly so i can retile over it, problem is if i board over it with the new tiles it will make the gap to small for the 760 door min ajustment is about 735
    it would apear to be like stud partitions made of straw looks like a paper face on it and then been plastered
    i did think mesh maybe then skim it with bonding or something
    any advice cheers ben
  2. Sponsored Links
  3. troweladdict
    troweladdict
    20 Jun 2010
    115
    Thanks Received:
    3
    Kent
    Country:
    id go with the mesh m8te and bonding if plaster board is out of the question 9.5mm board iv rendererd a straw building once it was lime render over mesh looked good in the end
  4. benwilliamson
    benwilliamson
    23 May 2010
    24
    Thanks Received:
    Lincolnshire
    Country:
    it seamed all loose and crappy, eml meshed it and rendered it with a mix of plaster board adhesive and sbr, perfect good as new and only about 3mm thick still cant get whats left stuck to my flex plastic bucket out, tiled it next day as well,, job done !!!
  5. roy c
    roy c
    19 Jan 2008
    2,373
    Thanks Received:
    422
    Country:
    I wouldn't of used bonding or plaster board at low level where a shower has been leaking! Maybe mesh and a few coats of s/c or backer board but never bonding.. :cry: Or plasterboard adhesive, it will go off solid but it wont hold the water back....
  6. joe-90
    joe-90
    28 Oct 2005
    31,284
    Thanks Received:
    1,062
    Country:
    I'm guessing that the SBR would make it waterproof?
  7. roy c
    roy c
    19 Jan 2008
    2,373
    Thanks Received:
    422
    Country:
    doesn't work like that Joe.... He could of used Waterproof tile adhesive Like Ardex or something similar.....
  8. joe-90
    joe-90
    28 Oct 2005
    31,284
    Thanks Received:
    1,062
    Country:
    How does it work then? SBR makes mortar waterproof - so in what way is it different?
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
