USB double socket (MK)
20 Feb 2008
Hull
I have a number of mk usb double sockets in use downstairs without issue. However, when we fitted one upstairs, it worked for a while, then the usb stopped charging our phones, or any other device. Thought it was a socket fault, so replaced it with another mk socket, and this one won't work on usb either. Is there something I should be doing with the wiring at the back or is it another dud?
The socket itself works.
Try a different cable and charger, if that fails time for a new socket, of charger with plug
Thank you for replying.
The cable works on other sockets.
Could be right, but thought I would check with you guys whether there were anything I should check before buying another one.
