Anyone have any experience of such set ups?
I have some good friends who have such a set up but a very strange anomaly exists.
The tank is 150l and the water is lifted to 50c by the ashp. (house is only usually 2 people).
blending to 38c gives a theoretical no losses duration of about 19 minutes based on an incoming temperature of 10c.
In reality, if the heatpump dhW is timed to be OFF when showing they get about 17-18 minutes, so far so good.
However, if the dHW is put to constant (as recommended by the manufacturer or ASHP and Cylinder) or the dHW is set to a timed cycle that is ON when showering, the availability of 38C hotwater fails after 11 to 12 minutes, a 33% reduction in available showering duration. At that point the ending tank temp will have fallen below 36C....
What seems to be happening is that the tank plate heat exchanger and pumped cct seem to be blending the whole tank to a blended temp as it passes through the plates and therefore not leaving the pocket of heated water on the top of the tank. And the only solution would be to wait for the entire tank to re-heat before being able to shower again....
Seems a strange outcome using what is marketed as a superior solution but actually is quite frustrating in use as you have to make sure the dHW is not active whilst drawing larger volumes of hot water....
Questions:
Is this what experienced users / installers of dhW tanks with plate heat exchangers would expect (especially those using ashps with lower flow temps).
Is there any solution apart from ditching the preplumbed expensive tank with plate heat exchanger for a coil based dhw tank?
Thanks in advance
Questions:
Thanks in advance
