Thanks to some forthought in loft conversion design my header tank is entombed behind a dry wall with a tiny inspection hatch. Rather that run a separate cold supply to my Shower pump, can I use a 15mm tee from the 22mm cold supply to the hot tank to supply the pump. I know this is not the best idea but if the consequences are not too hard to bear then it would make for a much easier job.
