Using Postcrete for footings of a small wall?
12 Apr 2007
Derby
Basically I have a fair amount of Rapid Set Post Mix(Agregate
Industries) left over from doing my fence and I was wondering about
using it for the footings for 2 small walls. One being about 3 bricks
high as a base for a shed and the other being similar for a step onto
a patio.
Or should I just buy normal concrete?
No reason while you can't use it. If you don't have enough then mix it in with some more cement/ballast.
Are there any issues with strength?
I dont want to use it then find it has cracked after a frost or something.
Rob
Rob
Frost is only a real problem for concrete while it's going off, so couple of days max. Quick, do it now before winter sets in :roll:
No, the walls you are building won't be affected by using it.
