I've seen a few threads on other forums talking about using Cat6 as speaker cable but recommendation is to braid it which sounds like a ball ache.
My setup is a multi-room 6 channel LivingControl Roombox6 which I'm planning to use to drive ceiling speakers in several rooms.
Some of these speakers have been previously wired in to some cheapo eBay car amps which works ok but they do suffer from crackling sometimes due to interference. Thoughts are both the cables in use (1mm twin & earth) and probably the amps causing it.
The new wiring between the Roombox6 & ceiling speakers will be predominately under floors & ceiling voids so there is the potential to be near other mains cables and other Cat6 for WiFi APs etc. Maximum cable run lengths will be in the region of 10-15m.
Is shielded cable the best option or just try and separate the cables as much as possible and ground the amp/speakers to minimise interference? Twin & Earth obviously has an earth core so that could be utilised.
I'll spend the money on decent cable if necessary but its not a case of 'money is no object'!
