I need to remove the offside front door panel but I am not sure how it is attached. Apart from removing the visible nuts/screws, how are the remaining sections of panel fixed to the door. Are they the usual plastic studs that push into holes in the door frame and are removed by gentle leverage?
Also, does removing the window handle need any special equipment or is it just held on by a screw or bolt ? This is my daughters car and I don't want to mess the panel up by forcing things. Any advice would be much apreciated.
